14' Series
Water on roof
Same here with my pop top JJOB...especially if running the air cond for a while...I always try to leave a few degrees drop to the rear...
Jan 20, 2026
14' Series
Water on roof
Its not just expandas most vans do, my old Tardis was the same and my full size non pop top rig, Big Mal has a number of small lakes...
Jan 20, 2026
R
rfox
14' Series
Water on roof
I really like all but one aspect of my Expanda. The thing I think is a problem is that when you have the van level, water sits on the...
Jan 20, 2026
R
rfox
Interior
Thickness of ceiling
Thanks Drover. I test drilled a little hole in the ceiling and it went in about 25 mm before I hit what I think was the outer (roof)...
Jan 20, 2026
Pace's post
Pace's Malibu Family Adventurer 20ft6 (custom build)
Warrnambool 2026. Our best setup yet, will be doing this again. Just line the van with the water post.
Jan 20, 2026
Pace
Jan 20, 2026
I have at last added the 3rd battery to the battery pack in my JJOB 17.55-1. When I originally upgraded the batteries from AGM to...
Jan 19, 2026
I wish that was the case with mine but sadly not ..... you could feel the vane arm grumbling when it should have moved smoothly...
Jan 19, 2026
I was reading a blog the other day, a fellow was having dramas with his Jeep going in to limp mode when towing, took it to a Dealer and...
Jan 19, 2026
S
Sparksy
None...they were all bought at the same time, same capacity, same make...and I had been using the 3rd battery in the car when I run the...
Jan 19, 2026
1400 kms covered and I would hate to see what the Transmission temps would have been in the 36c days when I was towing if I hadn't done...
Jan 19, 2026
Jan 18, 2026
So bigger and better Coffee Machine now ..... ???????
Jan 18, 2026
Jan 18, 2026
Dave, I do miss the Jeep the get up and go, the brilliant gear box and some of the bling I fear to say but in all honesty I do prefer...
Jan 16, 2026
