17' Series
Setec Unit
Thanks for the replies. If I remove the Setec unit does that mean that all of my lights can only run off 12V power even when I am...
Dec 8, 2025
B
BaldEd
17' Series
Setec Unit
Drover: So true. When my Jayco arrived from the factory, my memory may have dimmed a little since, but I seem to recall that only 2 or 3...
Dec 8, 2025
17' Series
Setec Unit
Hi all, I am pulling out my setec Unit as I do not use the battery charging aspect of it, so it has no use other than that. My...
Dec 7, 2025
I sold my boat to cover things, the Jeeps turbo had a fault which only showed itself when towing, 30kms and into limp mode, the fix...
Dec 7, 2025
With the new capacitor the fans fire up and then drop off momentarily and you can here the compressor try to start but jut gives a click...
Dec 7, 2025
Here I was thinking either the smart battery BS had been shut down or they dropped the stupid idea with this model............ WRONG...
Dec 7, 2025
Dec 7, 2025
The bracket is in the mail, well I have a tracking number but nothing else, so yesterday arvo I fit what I can and trim the skirt to get...
Dec 6, 2025
Dec 6, 2025
Ian, as you probably have realised by now, if the compressor starts up and runs (as you have tested?), and is compressing properly, then...
Dec 6, 2025
New capacitor turned up so confirmed old capacitor was knackered, fitted new one, fingers crossed, fired it up, left it running came...
Dec 5, 2025
Pace
As mentioned on another thread The Jeeperific has been replaced by Henry, a 2020 PX3 Ranger XL to be precise, a poverty pack with...
Dec 3, 2025
Pace
The new Centurion Hitch is quite good to set up, Big Mal hooked on and tucked in behind quite well, will need to do a Tranny fix, swap...
Dec 3, 2025
Pace
I bought the adjustable from the same mob as the stinger who imports them...
Dec 3, 2025
Pace
My great deal for a set of MSA mirrors for the Ranger just fell in a heap, ordered in October, then told nil stock due 5 Nov, be...
Dec 3, 2025
