Well its only money, bought a nice, new shiny Stinger hitch for the Jeep back in January, a great bit of kit but it doesn't have the...
Nov 6, 2025
What a unit !
Nov 6, 2025
Inverter install
Just redid my batteries into a box to comply as added a second battery . Using a 2600w inverter I went to batteries to Dual ANL fuse ...
Nov 6, 2025
Inverter install
Mine has as short a run as possible with a good ANL fuse, fat lugs and bolts. The potential weak point is the shunt in the negative...
Nov 6, 2025
Mikedebs
Exterior
Replacement water tank outlet
I have a 2005 Expanda 16 foot. Bought second hand with two fresh water tanks. The outlet at the bottom of the tank that feeds the water...
Nov 5, 2025
Wondered why the rear water tank was hard to fill...
Truly classic Dave................:D ............... when I first got Big Mal, would empty one tank but the next tank would be empty...
Nov 5, 2025
Inverter install
Agree with Drover...that's how I have wired inverters in the past...I used good battery cable straight to the inverter with shortest run...
Nov 5, 2025
Inverter install
General Caravaning Discussions
Hi all, Would like to get your thoughts on whether to wire my inverter through a busbar or straight to the battery? Any advice...
Nov 5, 2025
I too was perplexed initially when I bought this van, as the filler necks for the water tanks are back to front too...the front filler...
Nov 5, 2025
DRW's post
My last Jayco used to handle poorly when I emptied the rear tank, I couldn’t figure it out because my expanda used to handle better with...
Nov 5, 2025
Thought I'd do some maintenance to figure why the rear water tank was sooo slow to fill...aha... I found Jayco's way of making...
Nov 4, 2025
Nov 4, 2025
...only coming up 4 years...lol.
Nov 2, 2025
And how long has this taken you to find ????????????? :p
Nov 2, 2025
All Other Jayco Discussions (Non Expanda)
Nov 1, 2025
