Off Road or Not
Love
@chartrock and @Boots in Action hence my quote above .................................. two can play at that...
Sep 14, 2025
Suburban hotwater unit wont run unless door is open.
I thought it was a thermocouple, either way the prongs send a current to keep the solenoid open, looked in my manual and the prongs...
Sep 14, 2025
A good thing to rule out though. I have heard of a few cases where it was a problem with the regulator
Sep 13, 2025
Off Road or Not
Hi @chartrock , it is great that someone is monitoring some of these "way out suggestions" on behalf of Members. Personally, I think...
Sep 13, 2025
Off Road or Not
Hi @Drover, this guy is a newbie and is proposing to start discussions on fairly meaningless topics. He has proposed at least 5 subjects...
Sep 13, 2025
Off Road or Not
I'll bite .................................................... Mine runs on solar/battery which runs everything bar the fridge and HWS...
Sep 13, 2025
Thanks @Sparksy for that info and the fact that the Suburban hot water system does NOT use a thermocouple to keep gas valve open...
Sep 13, 2025
S
Sparksy
Thanks. But the suburban hot water doesnt use a thermocouple to hold the flame failure solenoid for gas flow. I can see your point but...
Sep 13, 2025
I dismantled the level indicator and other rubbish years ago, just pulled it all out and binned it, so the solenoid is all thats left...
Sep 13, 2025
Sparksy's post
After a incident where the solenoid jammed open , I fitted a isolating valve in the supply water line under the floor. On a side note ...
Sep 13, 2025
Well the Flood Alarm went off today, as the tide started to lap at my feet, the flush button on Dunny had jammed, quick race outside...
Sep 13, 2025
I had a similar problem regarding the thermocouple with my 3 way fridge. All was fine for months and then when I was testing fridge at...
Sep 13, 2025
It could be the probes but the board has a well documented fault where the sensitivity to the flame (well the current measured as the...
Sep 9, 2025
S
Sparksy
Sep 8, 2025
S
Sparksy
Ive cleaned the probes but if it was the board then the board would instantly switch off the gas. In this case the flame slowly looses...
Sep 8, 2025
