WTB hayman reese 30mm offset drop shank
Oct 13, 2012
54
5
Wanting to buy a hayman reese 30mm offset drop shank. Current standard isn't quite long enough for the SZ ford territory towing a 17-56.01. Would be willing to buy or to swap. Has anyone had this issue towing with a new territory?
brotys
667
261
leongatha
Howdy we have a 2013 awd territory same problem towing a 20/63-1 cant get van level front of van all ways sitting up at front tryed every thing even air bags to rear off car, to packing van diff got all most right but still not happy lets no how you go, we cant get different shank as we use hayman reese wdh.
17triton
3,717
5,438
Ballarat
Hayman Reese sell different length drop shanks @brotys at 50 mm intervals I had to get a longer one when we put a ARB rear bar on because it sit higher than standard.
17triton
3,717
5,438
Ballarat
Here is my new hitch on top of the old one you can see its 100mm lower. I think they only go in 50 mm increments up to 200. Just ring a Hayman Reese dealer.
darcy305
160
223
Meadow Heights
I had the same issue with our 2006 Territory finally found a 100mm drop hitch on ebay for only $50 which solved the problem and we use wdh as well. just have to keep an eye out for them they do come up on a regular basis.
cheers Darcy
Oct 13, 2012
54
5
We bit the bullet and finally got this sorted out through one of the local towbar and trailer places. We didn't just have to drop down to the next size, we had to drop down 2 sizes to the longer shank to get the van level when using the WDH. Just goes to show how the Jayco dealer fit stock standard for each van/car and don't actually judge each case on its merits. Ours is a 17.56-1 van with underslung axels and Jayco just fitted a standard shank with the 600lb WDH which obviously was not right. Happy now with the correct setup although $200 lighter in the wallet for the privilege (for something that should have been done correctly in the first place)
