No Options Apply Water Pump
Aug 20, 2016
69
25
Yackandandah
Water pump is working on 2017 14ft expanda but no water coming out of the mixer. I did run the pump while the tanks were empty (don't ask). Possibly air in lines.... any suggestions to fix?
MDS69
728
794
Do you have a HWS fitted and if so is there water in it. If there is water in the HWS have you tried flicking the tap to hot to try to draw water through.
19,493
If your tank lines to pump are clear check to see if water movement .............clean inline filter........ 3 way tap may be in wrong position or sucking air, pull off tank and pump line and using a joiner (50c from hardware 10 or 12mm )connect them together, if pumps then draws water the 3 way s stuffed..... if clear lines from tanks you can see if air bubbles are coming from an air leak ............................. you can have an air leak but water won't leak from it..................... to check for blockage start at tank, pull line off if water flows out with some force its good, if t just slops out then something is blocking the outlet, if it flows okay flush lines to make sure nothing blocking, small bits of plastic can cause big blockages around connectors, depending on pump there may be small mesh screens at entry point...
Reactions: Jack Lucy & Josh
