Hey guys,
Before I order the new parts I "think" I need, just wanted to see if anyone else has had this happen.
Over the weekend our top tank on the toilet ran continuously and filled the holding tank to the point where the top tank ran out of water. We could stop it by turning off the Battery Isolator switch as we were free camping.
After I removed the Control Panel as seen in the pic below it would stop the pump running.
I had a look and noticed that the button which is soldered to a circuit board had quite a lot of corrosion, so am presuming it is that. There was also quite a bit of moisture in the compartment when I removed the panel.
