solar regulator alarm
sledge
Banned
Feb 21, 2013
77
14
Sunbury
went into my shed this avo and found the solar regulator alarming and noted the battery had dropped to 10.9v so assumed this was the culprit. so just wondering if it will turn off automatically when the battery is charged and what the alarm level is set at?
the reason was probably the fact a light and the antenna booster had been left on for 2 weeks but was surprised as the solar panel does trickle charge through the skylights in the shed.......so just wondering that with the fridge being on left on DC if this draws from the battery as well, as I thought the fridge 12v feed only drew from the car hot wire?
Capt. Gadget
Dec 1, 2011
1,894
1,843
Busselton W.A.
bbmwa.com.au
Pretty sure the fridge only draws from the car battery would expect the solar to get a bit from the sun through skylights mine shows charge, although very little when parked under the carport ready to go away.
sledge
Banned
Feb 21, 2013
77
14
Sunbury
yeah thought so about the fridge feed. anyway after charging back up from 240V overnight the alarm has gone off and all good :)
