16' Series Solar Controller buzzing and buttons
cal32
4
sunshine coast
Hi
New Expanda owner here . We have a 2015 Outback 16.4 .
Tried running off battery first time (at night) to home as a test and after a while buzzing coming from controller and light went off . It seems to happen when voltage drops below 10.
So I then turned battery off and voltage climbed again and noise stopped. We run a deep cycle battery . What is happening here ?
I also noticed that pressing red buttons does nothing to change the display. Could I have a faulty unit ?
I am surprised that the battery may not be charged because we have had two days of sunshine so should i be concerned ?
thanks in advance for any advice
MDS69
728
794
Could have a flat battery. Plug your van into 240V power at home for a few days and make sure your battery master switch is turned on. Probably located adjacent to the solar controller. Looks like a light switch.
Reactions: PhilW
cal32
4
sunshine coast
Thanks MDS69 goo idea
I just discovered I don't have 15 amp outlet at my place so looks like I will need to get one .
With solar does the battery master switch need to be turned on to get solar charging battery of does it just do that automatically ?
MDS69
728
794
You don’t need a 15A power out.et at home. You can purchase a electrical accessory called Amphibian that will safely allow you to plug your 15A lead into the Amphibian then the Amphibian into your 10A power outlet in the house.
https://ampfibian.com.au/products/ 15A to 10A Power adaptor
Reactions: PhilW
Marv_mart
1,275
2,019
I turn my battery switch off when I have my van in storage. The Solar panels still charge up my battery. I have a remote battery monitor so about once week I download the data. There are some things in the van that always use some of the power stored in the battery so as you can see, there is a small fluctuation, down a bit at night, recharges the next day even when the caravan cover is on. Have had some very cloudy days recently so not a full recharge every day. Not bad since the van cover is pretty thick on top to protect from hail. Enough sun gets through to recharge.
This how my van is covered when in storage, battery still charges every day, battery switch turned off.
Hi
At 10v volts your battery is likely kapoot, especially is it creeps up quickly after disconnecting the load. Take the battery to a battery shop ie Battery World and they'll load test it for free
Reactions: Marv_mart
