You will find there are a lot of different ways to get power through to the van. I show a few of the more common ways bellow but these are by no means the only way it can be done. I show the others here for reference only but the single anderson hook up is what you are looking at. I have also made an edit to my previous post on a possible issue with connecting the original 7pin wire to the anderson.
The first picture shows the two ways that are very common in a standard Jayco wire up. The top diagram is most often seen when a smaller fridge is fitted. The fridge gets it's power before the setec then power goes through the diode in the setec to the battery. The diode will block power coming coming back from the van battery. Unfortunately it will also cause a voltage drop of up to .6v . It is common to see this used with a 7pin trailer plug.
The bottom diagram is used if you have a larger fridge installed. It calls for a double run of suitable cable to be run from the vehicle. One for the fridge and one to charge the battery. This attempts to minimise voltage drop by spreading the load between the two cables and at the same time still use wires that will fit in a 12pin plug. You will need to run an earth cable that can handle both loads as well and you will still get the voltage drop through the diode. You will notice no fuse is shown in the fridge wire, as this is a dedicated line to the fridge a suitably sized fuse on the vehicle is all that is needed.
The next picture shows a common single hook up using anderson connectors instead of the trailer connector. Anderson connectors come in a range of sizes, 50 amp is most common for van use. These connectors will allow you to use much heavier cable (6 b&s ) which will give less voltage drop and supply a larger current. In this diagram the setec has been by-passed and the cable connects directly to the battery. This removes the voltage drop caused by the diode but means the fridge will be connected directly to the battery as well. This could allow the fridge to flatten the battery if left turned on 12v when the van is parked. To help prevent this you can fit a low voltage cutout relay or a movement cutout relay.You should also be aware that this provides a direct connection between your van battery and your vehicle. If your Vehicle Anderson plug is live all the time the van could drain the vehicle battery as well when the engine is off.
The next diagram shows the use of a dc-dc charger(a ctek in this case but there are many others available) While it will work there are a couple of things to consider. First you will have the voltage drop from the setec diode, while not world ending it will reduce the efectivness of the ctek. Lets face it the main reason for fitting a dc-dc charger is to maximise the charge to your battery so you don't want anything in the way if it can be avoided. The other issue is the fridge will be using a portion of your 20A available from the ctek. Even a small fridge will probably use near to 10A and while the fridge will certainly enjoy the extra volts available to it, it could impact on the ctek's ability to charge your battery. if the battery was very flat it may take a lot longer to recharge. If you have a large fridge it will be even worse.
The last picture shows two diagrams of the ctek in use while by-passing the setec. the top diagram is very similar to the previous one except we have now avoided the voltage drop from the diode. However We could still run into problems if a large fridge is used. In the bottom diagram the fridge takes it's power from the input side of the ctek and leaves the ctek's full 20A available to the battery. Note that the fridge will have direct access to the vehicle battery so you would need to have some form of isolation for when the vehicle is switched off. like the motion switch shown or maybe a relay fitted in the vehicle that goes off with the ignition.
The other thing we have learned in
this thread is that the ctek unit (and some other voltage sensing devices) may not be a happy camper when it comes to some modern smart alternators. Add the extra bit of voltage drop you will get running back to your van and you may well need to use the Hack that ctek have provided to make it work. The ctek will need to see 13.1v before it will kick in and will then drop out if the supply drops below 12.8v . I think there may be a lot of people out there with the D250 fitted that may be in for a rude shock if it is ever called on to supply the full 20A.
