After visiting the Caravan & Camping Show on the weekend I have a few projects to get down now.
At the show I brought a
1. 12volt water pump
2. New tap to replace the pump style one
3. Axis dvd/cd head unit
I have ordered a Kogan 24" led with 12volt adapter
I have also just picked up a pair Alpine 300w 3 way 6x9's
I have already replaced the tap and fitted the pump, so no more hand pumping water. For the pump I took the power from the led light over the sink which as luck would have it had some extra plugs for me to use. I then just ran the wiring with the original wiring and into the wall cavity. I also added a pump switch so it can be turned off while travelling in case of a leak(I would not want the tank full of water pumped into the van).
So next is the fitting of the speakers.
I will up load photos soon.
