Power Problems
Droppedpie
Hi guys, i have recently become a happy owner but am experiencing problems with the 240v and battery power. i cant seem to get the 240 to feed directly to run the van. It is probably something very simple and stupid that i am doing. Also the battery seems to flick on and off intermittently. Any suggestions would be appreciated.
Head like a droppedpie
Big Gee
319
14
The ACT
Hi Droppedpie!
(wow even typing that feels rude)
In our van we have a circuit breaker in the little cupboard under the microwave! It's probably worth checking the fuses in the setec control panel & also that it is plugged in properly!
That's about all I know, hope it helps
Shaun
PMK
194
21
Sunbury Victoria
G'Day,
You don't say which van you have but... most are the same anyway
Have you checked that the safety switch is turned on, this may be the problem on mains 240 v. As for the battery switching on & off ... I'm sure some others on here will have an answer.
Cheers,
Paul.
G'day Droppedpie,
Congratulations on your van, hope you enjoy. I would be checking what PMK said, my setek is plugged into a surge protected double adaptor and then into power point under lounge....maybe it's suffered a surge. As for the battery though I'm not sure, maybe check voltage and fuses, could also be a bad earth somewhere if you have a meter I'd start to check things out.
Cheers Burnsy.
Droppedpie
thanks guys, found the trip switch on the van parks power box kept tripping, all good now.
Thanks Again
