Recently had a friend on the Sunshine Coast discuss his problems within his van regarding 3 way Dometic fridge operation - or should I say lack of proper operation - and hassles when stopped. With the help of members on this forum, I have a gained a very good knowledge on how, ( in Jayco vans anyway,) 3 way fridges are connected to tug, and how they operate both on and off grid. I mistakenly believed that all van connections were based on this same arrangement ie : 12 volt line from tug to provide power to Setec controller (or other brand) to put some charge into battery and a separate dedicated line direct to fridge terminals to keep fridge going whilst tug motor was running , and that when you stopped, a VSR or other relay type switch disconnected the charge line to prevent tug battery from trying to keep fridge operating until flat! But this is not the same with his 2004 Kedron XL van!! Or maybe it had been changed by previous owner???
He had been told it was necessary (and was doing so) , that every time he stopped, he had to get out of tug, open up van and turn fridge off 12 volt operation and run gas until moving again. The penalty for NOT doing this was a flat VAN battery and a flat tug battery if left long enough. Apparently the tug and van batteries are connected in parallel and so both carry the load until death!! I got him to check with the makers of Kedron vans at Brendale and they confirmed that the van fridge is powered by the van battery and that there is no dedicated line from tug direct to the 12 volt terminals of fridge - it only goes to the van battery. One can imagine that the fridge would not operate too well when voltages of tug and van were down to near 12 volts or below. Kedron at Brendale also told him that when the van is connected to 240 volt power, the first item to receive/absorbe power is a 12 volt charger which then has to charge up the battery to run the fridge until the unit is changed to 240 volt power operation. Is this normal for all Kedron vans of that vintage or later???
IMHO, this is a very crude and antiquated system. I know that my "other half" would not be impressed with this arrangement. Another thing too is that the van has a 100ah Gel battery and only has an unsophisticated older style "linear" 12 volt charger like the basic car charger of years ago, not the best for a Gel battery operation. A "smart" 12 volt charger would look after the battery much better.
Has anyone had this system? I am thinking of changing it to a more modern arrangement with a dedicated line from tug battery terminal direct to 12 volt terminals of fridge with a VSR in line. A separate line (fused) from the VSR could go directly to the battery to charge the battery and a modern "smart" 240 volt charger could replace the old "linear" type. As the the tug battery voltage would probably be too low on start up to close the contacts on the VSR, I would not need to connect a power diode in the circuit as current in this line would only come on when voltage exceeded 13.2 volts after start up.
I would appreciate any advices/warnings and comments before I start trying to improve my friend's older van and solve a few of his hassles with fridge operation.
