20' Series New 20:64-1 OB Hayman Reese (which drop shank Landcruiser LC200)
Derm
25
Mornington Peninsula
Evening,
Our new Expanda 20:64 OB has arrived and I have two drop shanks, a 50150 used this with a Prado and a 50153 with a Expanda 17:56 OB on the Cruiser. I will have to sell my 275kg 600lb hitch as the new OB has a ball weight of 279kg. I will need to buy an 800lb hitch but not sure which drop shank to buy as the others are either to high or to low. (The new OB are higher than the old OB due to suspension changes) Has anyone else had the same experience and is so can you suggest which one to buy, the other shanks are
Part nm. 50151 30mm Drop
Part nm. 50152 95mm Drop
Cheers,
Derm
Evening @Derm ,
All setups are different dependent on different vehicles and vans. If you aren't confident (or know someone that can check your setup) I would recommend taking your van to a dealer or supplier and get them to set it up for you and supply the proper shank straight off.
Smash
131
62
48
Perth WA
Evening,
Cheers,
Derm
Normally you need the 50152 95mm drop shank for Landcruiser 200 series with the extra height but some need the 160mm drop down shank depending on the lancruiser suspension best thing to do is to go to a main agent and there tell you how to measure.
Reactions: Derm
Derm
25
Thanks Smash,
Yep already have the 50153 (160 drop but it is to low) after doing the measurements will be getting the 50152.
Derm
