Electrical LED light replacement
KBerg Rig
27
7
Hello All
I'm looking at replacing all the standard lights in my 2010 17.56-2HL with LEDs
Can anyone advise where I should look to buy a complete set of LEDs as a package for my model or would anyone have a list of what's required?
Thanks Matt
I went to my local jayco dealer (page bros) and they had a display board where you could try different style globes.
boots33
708
679
Hello All
Thanks Matt
Hi Matt
The main types of bulbs used in the jayco's are
T10 wedge type bulb. Used in most of the cabin lights and the door handle light
For the rangehood usually two MR11 or a single Mr16 , you will need to measure the size to make sure
G4 Bulb in outside light
Those ones that @Smergen has shown look to be a good way to go but there are also other options available. Ebay is the best place to look.
These two threads are a good read if you are after ideas.
Leds
Annex Light
Smergen
2,354
4,716
Bacchus Marsh
I liked those sets @boots33 because they simply had one for each light in the van. Turned out we didn't need the range hood one and outside one but now they are spares.
Simply pull out the bulbs (they're in the spares draw too) and plug in the new ones. Might be some cheaper but I liked the simplicity of a 'set'
ShaneT
291
308
W.A
type into ebay "t10 36 smd" I brought theses, worked very well and at $1.50 each you cant go wrong. You can also get 48 led ones but I'm not sure about the heat, that's why I went the 36. They come with double sided tape on the back and the t10 cable.
boots33
708
679
Yeah I haven't looked for van leds for a while and was not aware of the "jayco sets" now being sold. they certainly would be a snap to install. i installed the 36 led stick on ones a few years back and they are still going great and still stuck on as well. one of the 48 led that i fitted to the outside light failed on our last trip so will replace it soon. Overall am still very happy .
Reactions: Smergen
