I mentioned in one of my threads that my Ibis AC made a thump when shutting down on heat mode. I sent an inquiry to Air Command and I had a phone call from Colin this morning. He agreed that the unit did make a thud and these are his suggestions and recommendations.
Now to test it out to see if this makes a difference.
@Brad @Burnsy @Paul75 Thought you guys might be interested in this thread.
- Don't run run the unit on Auto mode even though all their literature recommends this setting.
- Don't run the fan speed on Low. Always use Med as the minimum speed. His reasoning is that there is alot of back pressure in the unit, especially in heat mode, that builds up and the lower speed cant keep up with releasing this extra pressure. Therefore when the unit shuts down the pressure cause a shudder.
- In humid conditions also use Cool mode and Med fan speed as at lower fan speed condensation will build up in the fan and cause a build up of pressure causing a similar result as the heating mode.
