I have started raising the bed end in my 2014 14.4.40 Expandas to get rid of the very uncomfortable two thirds one third inner spring.
I hope to space under the aluminium framework rather than on top so I can get better storage height below.
I have loosened at the front and back of the frame and the back moves readily. The length sitting on the front veneered plywood however remains stuck.
My thinking is that there may be extra screws in behind the ends of the aluminium cross bars.
If this is the case I can access and remove. Problem solved.
If however the aluminium strip is glued to the ply then moving without damage to the veneer might be difficult.
Can anyone who has undertaken this modification let me know what fixing method they encountered.?
