Suspension Hayman reese wdh classic or standard
vince
13
11
geelong
Gday I'm after some help in deciding which wdh to get from Hayman reese , either the classic or the standard , the classic being a 2 piece spring or the standard being a 1 piece hockey stick type , currently pulling a 2015 17.56.2 outback expanda with a 150 series prado diesel , the standard looks like heaps of clearance around the draw bar but closer to the ground , cheers
804
I bought this https://camec.com/towing/towing-accessories-kits/pro-series-wdh-275kg.html which is a budget HR version. Works great but the downside is the small number of ball-angle adjustments compared to the more expensive HR. I think your choice depends on the clearance around the a-frame? Could have used either on mine but chose these because I take them off when (more) ground clearance is required - which is almost never because they still are higher off the ground than my dmax is.
