Engel In Van Whilst Travelling
paulie484
200
49
Perth WA
Not sure if discussed here before
If you have 12v socket in van, and you connect Engel to it, would you be able to travel and keep running if battery switch is flicked over to 12v ?
Ie. Save room in tow vehicle
Yep, we travel at times with 60L waeco in van, I did however wire another socket for this as waeco is a bit sensitive to voltage drop due to light gauge wires.
Capt. Gadget
Dec 1, 2011
1,894
1,843
Busselton W.A.
bbmwa.com.au
Ive moved mine into the van instead of the ute because the drain on the Aux battery in the ute with the expanda fridge and the engel drawing from it was too much now the Engel draws from the Van battery and the Expanda fridge from the Ute and all is good. Thought about fitting a DC DC Charger because the Aux battery is in the tray of the ute but it was easier to put the engel in the Van
Reactions: paulie484
