Hi All, being a "newbe" on this forum, I was hoping for some solid evidence on what can and cannot be done. Some caravan people tell you something and others dispute the same thing. I am the proud owner of a Jayco Penguin 2013 model with all LED lighting. I have noticed that the power cable from my tug vehicle to the van consists of two (2) 6mm wires black and pink plus a single thinner black one that branches off the pink one at the anderson plug. The two heavy wires go direcly to my fridge connections in the side panel behind the fridge and the thin black one seems to disappear behind the SETEC ST111 I0 amp model. I have a 20 amp PV controller connected from my solar panels also. The SETEC charger is only 10 amp max (and only 3 stage too) and with a 130 amp agm, battery, I found it better to use a 15 amp 7 stage battery charger to get the battery voltage up to 14.7 volts whilst the SETEC could only get it up to 14.05v. I have fitted a anderson plug on the side of the van and have run two 8 mm cables direct to the battery. Is this likely to damage the SETEC operation ?? I have been told that I must turn off the battery isolation switch also. Should I connect the battery charger to the anderson plug on the draw bar that connects the tug vehicle with the van? Can someone give some real advice?
