16' Series Door Handle
1DayIll
1,000
904
South Morang, Victoria
So I am at the caravan park starting to pack up the van ready to go home tomorrow and of all things the outside door handle breaks and i cannot get in. Easy I think, grab a pair of pliers and use them to open the door. Borrowed some and they did not work.
Then I worked out how to break in, will not promote how though as it may not be wise to promote it.
Lets just say I got in and now think i have rigged up a way of opening the door but need to try it properly tomorrow. Need someone on the inside just in case.
Will let you know if it works!
564
its even more fun when the lock breaks when you are inside the van, unless you have a phillips screwdriver handy you are stuck
Hylux
64
69
i replaced mine the other day, cracked but still worked. Apparently the original had the fault, new ones are ok
09 expanda
6
Queensland
A freind of mines handle broke off from a thief trying to break in so he just left the door unlocked and took the handle with him it just pushed in and you use it like normal
